Some of the older cd players, car or otherwise, just aren't capable of recognizing CD-RW's. The player in my 10 year old Ford Mondeo doesn't, but the updated model player in the newer Mondeo does play CD-RW's.
Either Cd is problematic or lens inside of cd player is covered with dust. There is no way of properly cleaning it unless you remove the cd player out and disassemble.
You may try cd cleaner kits but ususally they cant help.
RESET YOUR PLAYER AT DEFAULT SETTINGS. SWITCH IT OFF. SWITCH IT ON AND INSERT CD. GIVE THE PLAYER TIME TO READ. DON'T PRESS ANY BUTTONS TILL IT COMPLETE IT'S READING. IT WILL PLAY THE CD.
ALSO CHECK CD'S ARE BRANDED AND NOT COPY FROM COMPUTER. FEW COMPUTER WRITE CD NOT HAVE AUTO PLAY OPTION.
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
