There is water in the drain hose that will slosh if you move the tub assembly by hand. The drain pumps are apparently designed like that; to not drain all the water i mean. Could that be what you are hearing? Also debris in your filter basket may not be allowing machine to drain as much as it should. Not sure about your model but this video should show similar pump cleaning procedure. Hope it helps.
http://www.youtube.com/watch?v=8gNPHXV62YQ
SOURCE: maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
SOURCE: Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
SOURCE: Maytag Neptune Washer Wont Spin Water Off
I have a maytag too and this is a easy one and you will be so relieved when you get this done!! and your wife is going to love you toooo !! just unplug the machine 1ST then go to the back uncscrew the back panel right at the bottom of the machine is a pump its got a hose from the tub into the pump and then it leaves the pump into another hose to which leaves your home.... you can unbolt this.. take the hoses loose on both ends . Next take that the drain and hoses and wash them out / I found only a piece of paper clip around the little propeller of course i had to replace the pump but really its not that expensive. I got mine on line ebay.... like $ 20.00 but if you are lucky then you can clean that good. I even went as far as taking it apart a total of 10 minutes tops, just to find out what could be letting this not spin.... maybe yours wont be so tramatic but if it is be relieved when you know it was this simple to fix !!! good luck to you and yours.
SOURCE: My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
SOURCE: Maytag Neptune Washer - bleach and softner do not
clean water inlet filter,then check to see if the outlet tubes from the dispenser to the tub are blocked or partially blocked with detergent.
I use liquid detergent... no problem.
Cheers
