SOURCE: Can't see the top or bottom of screen on my emerson 32" Flat Scre
If it's like mine, there should be a screen mode button on your remote. Keep pressing it to change to different settings.
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
SOURCE: I need to program my direct tv remote to my
There are a number of different remotes that Directv use, and instructions may differ from your particular model. If you look at the upper left hand corner on the face of the remote there will be a model # RC-64, RC-23, RC-24, RC-32RF, etc. Click on the link HERE and on the webpage, scroll down and you will find the instructions to program your specific model DirecTV remote for your Emerson TV. I hope this helps and good luck!
SOURCE: Emerson LED Flat Screen 22
Check its power supply regulator board for any loose solder terminals. Might need replacement.
