Older model of gun. Cleaned the tool and reassembled it . Tool does not fire. Fan switch and spark plug are working. Checked fuel cell and it is ok. Retightened cylinder screws and checked alignment/operation of of tip.
SOURCE: paslode im250 f-16 only able to drive 2 nails .
Bad Fuel cell!!! New cyliders now have expire date on bottom of cannister. If old will not fire properly. Put new fuel cell in should be fine.
SOURCE: Paslode framing nailer loss of power.
Here's what I found at the Paslode Troubleshooting Site:
Tool will not cycle - fan runs, indicator light
is solid green.
Lockout bracket is stuck in lockout position.
Work-contacting element is bent, or build-up of
debris in track restricts operation.
Follower is not behind fasteners.
Fuel Cell empty.
Spark wire out of spark plug.
Spark plug is dirty.
No spark is generated.
Check lockout.
Remove and inspect lower probe. Clean and
lubricate track with Paslode Impulse® oil.
Repair or replace lower probe as required.
Position follower behind fasteners.
Replace fuel cell.
Remove cap and check spark lead, insert in
spark plug and replace cover.
Clean tool cylinder head and spark plug.
If this doesn't work, I suggest contacting Paslode directly 800-222-6990
SOURCE: i have paslode finishing nail gun , i cleaned it, not working now
The smoking is normal for a few times after cleaning ,but you might have put to much oil drops in chamber and piston chamber is getting a "vapor lock". Try recleaning with degreaser. Also have you forgotten to set the depth gauge at front of nose.
Please Rate jj505 Thanks
SOURCE: Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
SOURCE: nail gun won't fire
Try this. Take the handle off the tool per the cleaning instructions. Install the battery and push down on the roller lever in the upper handle. It's located close to the fan blade. (Item 27 on the tool schematic.) Keep your finger out of the way or the fan will bite you.
If the fan goes on, then the roller lever is bent and needs replacing or adjusting.
If the fan does not go on, release the lever and pull the trigger. If the fan works, then the molded circuit board needs to be replaced.
