Computers & Internet Logo
WALTER ROSS Posted on Jun 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turn off hp officejet 4500 last printing report
Prints a report after every printing of a document. It looks like the following: filename Folder Macintosh OSX-user:mac;DESKTOP Template: Support: Microsoft:Office:User Templates:Normal.dotm tkitle: Subject: Author: Keywords: Comments: Creation Date: Change Number: Lst Saved on: Last Sved by: Total Editing Time Last Printed On: As of Last complete Printing Number of Pages: 2 Number of Words; 111 (approx.) number of Characgters 638 (approx.)
Larry Ng
Level 3:
Top Expert:
  • HP Master 14,585 Answers
  • Posted on Jun 11, 2017
Larry Ng
HP Master
Level 3:
Top Expert:
Answers
14585
Questions
0
Helped
3277253
Points
66542
I have J4580 ,
reset it?
reload the HP software from OSX.
check the setting for the verbose mode turn on?
that is a feature set of this series.
turn it off.
read the manual, find that and turn it off is my best guess.
or reload it all.
Why does my printer print 1 blank page before printing material
Wild guess: uninstall your printer, remove drivers, look if new drivers are avaulable at HP for your printer and your operating system version and reinstall the printer.
Hp officejet 4500 prints very slow
Hello PL53,
Please try making a photocopy of a document and let me know if the time taken to make a copy is equal to that of printing from pc.
Hp officejet 4500 will not print from mac ibook g4
HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers - The All-in-One Does Not Pick Up or Feed Paper Issue The product does not pick up or feed paper from the paper tray. How to use the solutions in this document To resolve the issue, try each solution in this document in the order presented. c01733891.gif IMPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table. How to print a self-test report
  1. Load plain, white paper in the paper tray.
  2. Press and hold the Cancel button (c01235250.gif ) on the product control panel.
  3. While holding the Cancel button (c01235250.gif ), press the OK button (c01961874.gif ). The self-test report prints.
NOTE: Refer back to the steps in this table after attempting each solution. Solution one: Reset the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button (c01602202.gif ) to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the test page prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the test page does not print , continue with the next solution.
Solution two: Check the paper The condition of the paper or the amount of paper loaded might prevent the rollers from picking it up and feeding it through the product. Use the following steps to check the paper in the input tray.
  1. Remove any wrinkled or damaged paper from the input tray.
  2. Make sure that all the paper is the same size and type.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper contains from 10 to 25 sheets of paper.
    NOTE: Do not overload the input tray. Make sure the stack of paper is shorter than the top of the paper width guide.
  5. Insert the stack of paper into the product, and then gently push the paper width guide snugly against the paper. Figure 1: Load paper c01970609.gif 1 - Load paper 2 - Adjust the paper width guide Illustration of loading paper and adjusting the paper width guide
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution three: Check the print settings The paper settings in the print driver must match the paper size and type loaded in the product. Use the following instructions to adjust the paper settings.
  1. In the software program you are printing from, click File .
  2. Click Print , and then click Setup , Properties , or Preferences .
    NOTE: The specific options might vary depending on the software program.
  3. Click the Features tab.
  4. In the Basic Options pane, select More from the Paper sizes drop-down list.
  5. Select the size of paper loaded in the product, and then click OK .
  6. In the Basic Options pane, select More from the Paper type drop-down list.
  7. Select the type of paper that you loaded, and then click OK .
    NOTE: These changes do not change the default print settings. The print settings revert to the default settings the next time you open the program.
  8. Change any other print settings necessary, and then click OK .
  9. Click OK to print.
  10. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution four: Clean the rollers Follow these steps to clean the rear rollers and the pick rollers on the HP product. Step One: Clean the rear rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 2: Remove the rear access door c01961876.gif Remove the rear access door
  4. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the paper rollers. Rotate the rollers with your fingers to clean all the way around. Figure 3: Clean the rollers c00246512.jpg Graphic: Showing paper rollers
  5. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely. Figure 4: Access door rollers c01590938.gif Access door rollers
  6. Allow the rollers to dry completely.
  7. Reattach the rear access door. Push the door forward until it snaps into place.
Step two: Clean the pick roller
  1. Remove any paper from the paper tray.
  2. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 5: Remove the rear access door c01961876.gif Remove the rear access door Figure 6: Rear rollers and location of pick roller c01976220.gif Image: Rear rollers and location of pick roller
  3. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the pick roller. Rotate the pick roller upward with your fingers to clean all the way around. Figure 7: Pick roller c01975068.gif Image: Pick roller in the product
  4. Make sure that the pick roller and the rollers around it are clean, free of paper bits, and rotate freely.
  5. Allow the pick roller to dry completely.
  6. Reattach the rear access door. Push the door forward until it snaps into place.
  7. Load the tray with plain white paper.
  8. Reconnect the power cord to the rear of the product.
  9. Press the Power button (c01602202.gif ) to turn on the product.
Solution five: Service the All-in-One
My printer is printing a report after we print something
suggested solution:
if the document is in word 2007 follow these steps:
click Office Button - Word options -- Display - Printing Options. Under Printing Options UN-CHECK Print document properties and Print hidden text.
Hope this will work
Kila la kheri
Mpendazote Mkude
22helpful
HP Officejet 4500 Incompatible Black Cartridge
I have an HP officejet 4500. When I replace cartridge the printer reported Incompatible print cartridge. How can I get the printer to accept the cartridge and start printing again? The color cartridge is original to the printer and the black cartridge is the "new" one.
2answers
I HAVE A MAC OS X 10.4.11. HP OFFICE JET 4500. HOW DO I SCAN? WHAT OPENS ON MY COMPUTER? WHAT SOFTWARE SHOULD I HAVE? I SAW I PHOTO OPEN BUT DID NOT SEE MY DOCUMENT.
OS X driver which allows your Mac to interface with a HP Officejet 4500 wireless all-in-one printer
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
3helpful
3answers
Just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
2helpful
2answers
Print cartridge problem : [Tri- color]
Printer display says: Print cartridge problem : [Tri-Color]. Refer to device documentation to troubleshoot. I can find nothing in the 'device documentation' to help me.
2helpful
Prints a decription of my print job on one page ... additional unwanted page.
It sounds like you are printing from Word 2007. Go to the Office Button, Print, Print, Options and under "Printing Options" uncheck the "Print Document Properties" box.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
