Well M8, since you cant run the antivirus on your pc, try to run n antivirus program online.
http://www.kaspersky.com/virusscanner
You dont need to instal anything, just follow the instructions and Kaspersky will help you get rid of your viruses/trojan online.
Good luck to you M8!
Download and run AVG Free 8.0 anti-virus (here), then download CCleaner (here) and run 'cleaner' first, then run 'registry' from CCleaner's left-side menu. Next, defragment your computer. 99% of your problem should now be fixed unless there was serious damage to Windows itself. Make sure that you set a restore point (in system restore from control panel) between running AVG and CCleaner and follow all of it's back-up prompts.
The process "winlogon.exe" runs in the background. Winlogon
Note: The winlogon.exe file is located in the folder C:\Windows\System32. In other cases, winlogon.exe is a virus, spyware, trojan or worm! Check this with Security Task Manager."
Microsoft designed Windows so many small applications perform their tasks without a user knowing about it.
Normally, this will run smoothly and without flaw, but every once in a while, an issue can come up.
Winlogon.exe is an application that runs on start-up, and its primary function is to monitor the use of other applications.
Winlogon.exe typically only runs for about a minute or two when Windows first boots up, so if for some reason it is still running five or 10 minutes later, it could be infected.
Spyware and other malware would infect this application because it can manipulate other programs in Windows, causing problems.
If this is the case, the file might need to be removed.
if you want to remove this from
Open "My Computer" and select the "C:" drive.
Double click the "Windows" folder, then select "System 32." Navigate through the System 32 folder until you find "Winlogon.exe."
Click the "Winlogon.exe" file and hit "Delete." Select "Yes" when asked if you're sure you want to remove the program.
hope this helps
No. I tried the trial pack avinstall .. while installing also there were many pop ups , but it got installed..But, its not opening so m unable to run scan process..
Did u tryed to run the antivirus program is safe mode?
