You need to set up the dish box for the correct resolution ie 720/1080 etc.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to change your TV back to the proper input or channel. If the TV remote is not working to change the channels you can also use the buttons on the front of the TV. First look for a button listed as either input, TV/video, source or AUX. When you press this button it will start cycling through all the inputs available, make sure to cycle through them slowly because it make take a couple seconds for the picture to come in. If you do not find a picture on any of the inputs you are going to need to try the different channels. Normally for a TV where the receiver box is the TV should be set to channel 3 or 4. Once you have found your DISH Network picture you will want to make sure to push the SAT button on the DISH remote so that it doesn't change the TV channel again. I hope you find this information useful and if you have any further questions or concerns please let me know. Thanks. :)
If you are hearing audio but no picture unplug the receiver for 10 seconds and plug back in. This will reset the receiver and it will reboot itself for you once plugged in. This should resolve the issue, but if you continue to experience problems please e-mail me at nick.franta@dishnetwork and we may need to replace the receiver.
It sounds like either on the 612 or the Yamaha Receiver that the HDMI port is faulty, thus causing the flashing picture. It sounds like the 612 to the TV works fine. I would recommend replacing the Yamaha, and if problem persists then try replacing the 612.
Sometimess it is the dish receiver have you tried rebooting the dish receiver, hold down the power button on the dish receiver until the picture goes away then turn the button aloose then don't mess with it until the receiver reboots, then see if your audio returns.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
you problem is with your dish box. unplug the power cable and wait 2 minutes. plug back in an hopefully resetting will have solved. if not, contact dish for a new box
ya dish network reg box isnt hd ok u need call dish get hdtv box then u can use hdmi cable to get hi end picture ok for now use cox cable like u do to u can upgrade dish hd sumday k
