I have changed the leads and subwoofer and the amp is still not driving the sub,
please help
kindest regards
Richard
Have you connected the Subwoofer out to the "Pre-out Subwoofer" on the left bottom corner jack(looking from the back)?
Have you set subwoofer out in the menu(under speaker settings or similar menu you will find all the channels that you have connected and here you should have "YES" for the subwoofer)?
HTH
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
At the Onkyo, check to make sure you have run the speaker setup starting on Page 40. If that doesn't work...
Disconnect the subwoofer pre-out at the Onkyo and move it to the VCR Out, tune an FM station and be ready for some real loud subwoofer output if your sub has no volume control of its own. If you can hear the sub, it works and it's back to the Onkyo. If not, the unnamed sub
1.Press the [AMP] button on the remote and then press [SETUP] button.
2. Use the Up and Down arrow buttons to select "1. SP Config," and then press the [ENTER] button.
3. use up and down arrow to select subwoofer setting.
3. While the subwoofer setting is selected, use the Left and Right arrow buttons to select Yes .
you will surly get the audio from the subwoofer.
ok
