Televison & Video Logo
Anonymous Posted on Dec 23, 2012
Mitsubishi DLP (WD 65735) has no picture and no sound. Only a blinking green light that stays on for a few seconds then switches off along with the TV. Is this the "green death"?
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
My tv will power up with the with no sound for about 60 seconds then shuts off with grin flashing light for about 60 seconds the red light comes on amid stays on. What is the problem? The fan comes on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mitsubishi wd 65735 green light is blinking when power is applied tv will not power up
Green light blinking is set trying to boot up, no boot and of course set will not turn on, boot should take seventy seconds or so from plug in, if it does not stop blinking that is called the blinking light of death, as so many had this problem, probable going to have to replace the chassis if it is original one and that is usually five hundred plus parts and labor, just Google the model number with problems to see what I mean.
3helpful
My mitsubishi WD-65735 1080P has a green blinking light under the word lamp..what does that mean?
all these sets have a boot up if unplugged.
If power is lost or disconnected when reconnected green light will blink for about 70 seconds (set is rebooting) and then go off allowing set to be turned on.
Questions?
1helpful
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
