It spins, but the clothes are sopping wet when I take them out, I can twist water right out of them.
SOURCE: washer won't agitate or spin
Check for a broken or worn motor coupling (behind the motor), it connects the motor to the transmission. If your even a little handy, you should be able to replace it on your own.
Let me know if you need any guidance.
SOURCE: Washer sometimes leaves clothes sopping wet - then the next day O
you can remove the bottom access panel to get to the drain pump. there might be something in the coin trap.
