SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
SOURCE: new weed eater 13" electric trimer, want to change the spool
Usually one get a a spool of the cutting wire and it snaps into place.
http://flymolawnmower.co.cc/reviews-Toro_Electric_Trimmer_Replacement_Spool_with_065_Inch_by_10_Foot_Line_88185-B00005V7KY.html
Shows you also how to do it on package.
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need opposing force.
