Mitsubishi VS-60609 60" Rear Projection Television Logo
Christopher Happe Posted on Dec 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tv will not turn on
Have tried resetting it, and plugging it into different outlets
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Dec 22, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715347
Points
48227
Does the set if model listed here is correct come on with the green power light for a few seconds and then that goes off?
Turn tv on no power
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Tv won't turn on. Flashing 5 times
My Sony Grand WEGA LCD rear projection 51" turns itself OFF every 20 sek and turns itself back ON after every 35 sek. ???
Try resetting the TV to the factory settings. Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
When i turn the volume up or down its hard to read and the screen blinks blue and green when it turns off
Red color waving dowm
Try connecting any other device to the TV to confirm the issue.
It has wavy lines when you turn it on until it warms up it still does it but not as bad
My tv turn on for a second and after turn off. it is hitachi 52" old brand.
My tv Sony , has vertical lines
Try connecting any other device to the TV to confirm the issue. Try resetting the TV to the factory settings. Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
4helpful
Does not turn on, light flashes, it clicks once, the remote control will not even turn the light on
Please follow the below troubleshooting steps: 1. If the Television is plugged into a surge protector, remove it from the surge protector and plug it directly into the wall outlet. 2. Try connecting the TV to a different AC wall outlet. 3. Try power resetting the TV. To Reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power ON the TV. 4. If the issue still persists, TV will require service.
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
