Hye, I am having problem with nokia 6233. it is starting well with sound , all working good but display is very dull,i can see it but its too dull , its original battery is not working so i attached my other mobile nokia asha's battery by sellotape, should i buy a new display or its a battery related!!????
SOURCE: tracing lost nokia 6233 mobile phone provided imei no....plz help
i have iose my mobile nokia6233
SOURCE: Nokia 6233 slow start up and problem in SWF themes
You have to check your firmware version using this code *#0000# if the version is older than 05.60 .you have to update thru nokia pc suit.sure it works.
SOURCE: forget master code my mobile phone nokia 6233 plz send me master
IMEI: 359727005394973
Mastercode: 7226647030
SOURCE: white display on Nokia 6233
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
SOURCE: my nokia 6233 headset symbol
your headset socket may be shorted cleaning it may fix your problem.
