Bose Acoustimass 6 III System Logo
Nathaniel Hinckson Posted on Jun 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bose Acoustimass 6 No Subwoofer sound
Bought this system about a month ago. Was working fine until I noticed the base was no longer booming. On closer inspection I discovered there was no sound coming from the subwoofer on the Bose module. I doublechecked my cables, connections, checked through the menu for my receiver (Sony) and found no problem. The other mini bose apeakers work fine but absolutely nothing from the sub woofer. HELP! I'm about to drag it back to Circuit City but want to make sure it's nothing small that I've overlooked. Any advice will be appreciated.
A
Anonymous
We had the same problem, finally came to the conclusion the sub had blown,but then we thought we would check one last thing,even thought we had checked EVERYTHING, and we revered the speaker wire connections going to our reciever and that corrected the problem,the sub started sucking air and booming like it always did. sometimes its the simple things.
Anonymous
Level 3:
  • Master 883 Answers
  • Posted on Jun 17, 2007
Anonymous
Master
Level 3:
Answers
883
Questions
0
Helped
748059
Points
2537
Take it back for refund or exchange without delay. Too many times, there are cases of faulty factory assembly. Most likely a poorly connected wire inside sub, which fell off after a few booms.
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
http://www.bose.co.uk/GB/en/images/Lifestyle%2012%20Series%20II%20Home%20Theater%20System_tcm6-4071.pdf
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
5helpful
Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
I am unable to get the required base sound from my Acoustimass 16
Read the clues - Out of Phase means you have one or more of the speakers wired minus (-) to plus (+) instead of like pole to like pole. Having any speakers out of phase with their counterparts can **** the bass response out of the room. Check your wiring.
2answers
Geiger counter sound from subwoofer
If it's a wireless system, the circuits are drifting off frequency or could be picking up interference from just about anything. If not wireless, you probably have a part (transistor or chip) inside that is developing noise by itself.
6helpful
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
