Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
Posted on Dec 22, 2012
My bosch dishwasher uses all the salt in one wash
2 Related Answers
Anonymous
  • Posted on Dec 21, 2008
SOURCE: shv55mo3gb/40- built in - 4 yrs old
CAN I RESET MY DISHWASHER
Anonymous
  • Posted on Apr 16, 2009
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Glasses dull after wash
get the dishwasher filtration system at www.dishwasherfilter.com. this product was made to solve this problem. awesome product and guaranteed results.
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
2helpful
2answers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 • Dishwashers
5helpful
Just moved into a house with fitted NEFF dishwasher, never had one before and no manual left. Where do salts go? Thanks
The salt goes in the salt compartment in the base of the dishwasher. Open the door and pull the lower basket out. You should then be able to see a cap near the front-left corner of the base of the dishwasher. Unscrew this cap (anti-clockwise) and fill the compartment with salt all the way to the top - or with as much salt as you have in the packet - then screw the cap back on firmly, but do not over-tighten it. The salt compartment will (or should!) be full of water and some will spill out as you fill it with salt. This is totally normal and not indicative of any problem.
Do not use any type of salt which is not sold specifically for dishwashers. The dishwasher can be used without salt but it is not advised and may result in a white film being left on your cutlery, glassware and/or dishes.
It may also be possible to provide a user manual in PDF format which you can download, but I would need to know the model number. If you don't know the model number Most Neff/Bosch dishwashers have the model number laser-etched into the stainless-steel at the top of the inner-door or the rim of the washing compartment. Please click on the link below for a guide to locating the model number of your dishwasher. (Neff is a Bosch owned brand)
http://www.bosch-home.co.uk/type-plate-details.html?aftersales=dishwashing&aftersales=dishwashers~16468
Hope this helps. Please let me know if you would like the manual or need further assistance.
Regards,
BElectric
How much salt should you use in a refill of a dishwasher in a hard water area
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Water hardness is measured in either European °E (clarks) or in the German °dH ( Deutsche Härte) you will find this on all Bosch Dishwashers here is the comparisons for the two.
If your water is Very Extremley hard then you will need to program your Bosch dishwasher using the Code
H:06 to give you maximum protection here is a comparison table for the codes and the Clark and Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
1helpful
Bosch dish washer leaving black marks on silverwarelike it is burnt on any one else have this problem
THIS IS CAUSED BY REACTION BEETWEEN YOURE SILVERWARE AND THE DETERGENTS/SALT YOU ARE USING A CATALYTIC REACTION TAKES PLACE WHERE THEY TOUCH CAUSING THE FINISH TO PIT AND BURN OFF TRY USING A DETERGENT WITH SALT AND RINSE AID COMBINED AND A HOTTER WASH THESE ARE IMPOSSIBLE TO OVER OR UNDER DOSE WITH.
2helpful
Problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
