A recently visiting 'washing machine expert' and I are baffled. I have a Hotpoint BWM20 washing machines which has recently just stopped working. When we try and select any programme, then press the 'on' button, the timer clicks round 1 notch but then nothing happens, at all (not even the usual drum 'jerk' to check the drum isn't jammed). We have:
- checked water supply, fine.
- changed the pump, no difference.
- checked all hoses for blockages, nothing.
- checked for loose connections, none obvious.
- checked the belt and drum (fine + spin ok by hand)
The power and timer seem fine. The only thing that we have spotted is that, once the timer has clicked a notch, there is a 'white box' at the rear bottom of the washing machines which makes an electrical 'buzzing' noise.
Any thoughts / tips out there, or is this lovely white good heading for the scrap heap?
Many thanks
Thanks for the input tresilla... I think for £75 + P&P + fitting; it's going to be heading for the tip and us out shopping for a new machine! Just can't justify spending that much on a gamble...
Thanks for the 2nd opinion... what a waste for the sakes of a small board with a copper coil on it...!Thanks for the input tresilla... I think for £75 + P&P + fitting; it's going to be heading for the tip and us out shopping for a new machine! Just can't justify spending that much on a gamble...
You can't post conmments that contain an email address.
The white box you refer to contains the main module which drives the whole issue.
with no start, this module is probably faulty and is an expensive part
What does F6 mean on Hotpoint washing machine?
F06 - Door lock fault. Issue: Washing Machines door cannot be opened or closed / when the door is closed the machine the programme will not start. Advice: If your washing machines door will not close, please check for any obstructions in the door lock.
here is a link to a video to show you what to do
https://www.google.com/search?q=How+to+drain+Hotpoint+Aquarius+WD420+washing+machine%3F&rlz=1C1CHBF_enUS1011US1011&sxsrf=ALiCzsYpV67reJ4flOLBO4HC_Z3DecQ5Og%3A165
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
31 Oct 2009 - 15 posts - 11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
19 Mar 2011 - 14 posts - 9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
Adwww.hotpoint.co.uk/SparePartsrating for hotpoint.co.uk
Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
Price Match Guarantee · Spend £35 & Save £5
Isolate from electrical supply.Remove plinth which gives access to drain pipe and pump - drain, remove plug and and any debry, then check that pump revolves freely. Remove top and ensure that the tube connected to pressure swich isnt blocked.
I am not an expert on hoover - mainly hotpoint...but..
To empty your machine of water reset the programmer to Final spin. the machine should empty normally.
On hotpoint if you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor. (Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Normally these spin problems are just a blocked filter, which is located at the bottom of the washer behind a white panel which you can undo with a coin, drain water first, undo plug from hose into a bowl etc then take out filter and clean, hope this helps.
poss the interlock or the module has gone I have found that the neutral suppy on the board to the interlock can breakdown if the module has gone call an expert has these modules when new need to be configured to your machine as 1 module can serve about 10 models
