Question about Sanyo VPC-S500 Digital Camera
Turn on the camera, the start screen shows up and slowly turns to black. I don't see a thing. I tried to take a picture and check it using card reader, I saw picture I took was very clear on my co
    New Friend:
  • 31 Answers
Yes, your screen is dead. You really don't have any options other than to return it to the manufacturer for repair. :(
Posted on Dec 19, 2017
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Broken screen
some sellers on ebay have screen for select models of cameras. that would be the cheapest way to do it.
Posted on Nov 06, 2008
Anonymous
SOURCE: Card Error
Are you getting this error with the card?
If so, insert the card into the computer. Make sure you get all the files off before you continue. Then go to my computer, right click on the drive, click properties, click the tools tab and click check now. Just do Automatically fix file system errors and click start. This should successfully find errors if present on the card and fix it. You may lose a picture or two if you don't transfer all of them first. Or you could format the card by right clicking on the card drive and clicking format.
If you get the error on the camera without the card in it, turn it on and click mode button twice to get to the picture display (it should be a black screen with "memory error" on top). Then press menu and use the 4-way button to go to the right for Setup. Then use the 4-way button to go down to format to format the camera.
This should fix it.
Posted on May 18, 2009
Anonymous
SOURCE: Black screen
Try cycling through the Display button until you're able to view photo to be taken.
Posted on May 26, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: Blank screen when I try to click pictures
kindly call sanyo they will do it FREE it is a known problem
BAD CCD
Pl,s RATE ME WELL !
Posted on May 29, 2009
fotomohamed
mohamed salim shaikh
  • 321 Answers
SOURCE: Recharged battery, turn on, stays on about 2 seconds then off
its a batt. problem use NiMH enelop cell
Posted on Jun 18, 2009
My camera shows black screen and I cannot see if I was able to take pictures or what. The screen just do not show anything. It's all black. What I can do for this? Any help??? Thanks!
You're right in saying that if you get ANY onscreen message with the computer connected, the LCD and its driver circuits are likely OK. I don't have that exact cybershot, but I have had a few, and most have a menu item to turn off various screen content, including the entire display. Its likely a battery saving feature, but if you turn it on and hit the MENU button and still see nothing, there must be some actual defect. If all else fails, before contacting SONY, take the battery out and wait at least 5 minutes and then replace.
May 07, 2017 | Sony Cybershot W330 Digital Camera
Hello, On the C743 this will require that the LCD unit be replaced. This will get very costly real quick unless you can do it yourself. Not much more I can tell you.
Best Regards, Russell
Dec 22, 2012 | Kodak EasyShare C743 Digital Camera
SAMSUNG ST95: WHEN I TURN IT ON THE TOUCH SCREEN IS BLACK WITH CURSORS ON IT(^V) ALSO SAYS SAMSUNG AND MENU AND OK ON IT. iT IS COMPLETLY FROZEN AND DOES NOTHING.
9_28_2012_7_46_40_am.jpg ST95 SAMSUNG CAMERA
THIS IS THE PROBLEM WITH MY CAMERA I NEED SOME HELP FOR THAT WHEN I OPEN MY CAMERA ITS SHOW'S THIS THING AND THEN I TRY CLICKING ON OK AND MENU AN BUTTONS BUT NO THING WORKS IF I TAKE OUT THE BATTERY AND PUT AT IN AFTER ONE DAY THEN ITS OPEN BUT IF I TURN IT OFF AND TURN ON AGAIN OR IF I TRY TO TAKE A PICTURE WITH IT LENS COME OUT AND THEN GO BACK AND THEN ITS TURN OFF IT SELF NOW IF I TURN ON AGAIN ITS SHOW'S THE SAME PROBLEM I DON'T KNOW IF ITS THE SETTING OR WHAT PLEASE HELP ME THANK YOU.
Jun 21, 2012 | Samsung ST95 Digital Camera
When I turn on my camera I get a black screen
The camera is either set to a power save mode or the screen has failed.
Check your user guide for power save settings, if you don't have one, you should be able to download one from here:-
http://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_Camera/PowerShot/PowerShot_A2200/
Mar 03, 2012 | Canon A2200 Digital Camera
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
There is something wrong with my flash screen. It's Black. Everytime I try to take pictures on My Finepix z fujifil blue digital camera the screen goes black, and when I go to see what I took a picture...
Flash screen? What? You mean even in pictures with flash disabled (and the flash does drag down the electronics in the thing; make a replacement using an LED lamp and circuit if you have a chance) it takes no picture and leaves you with a black LCD? Are you indeed using a good battery (they go bad gradually (depending on the case on how many times you fire the flash!)) New battery first!
Aug 25, 2011 | Fuji FinePix Z10fd Digital Camera
When I turn the camera on the screen is black. It shows the menu display ok and it will display pictures already taken but it is not possible to take pictures as the screen is just black..
Two things there, first... could be a problem with the viewer screen, or, second choice could be a problem with the CCD sensor or go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Canon service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps; check it and keep us updated..
Aug 15, 2011 | Canon PowerShot SX130 IS Digital Camera
Finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
Oct 20, 2008 | Fuji FinePix Z10fd Digital Camera
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Sanyo VPC-S500 Digital Camera Logo
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
