Whirlpool WRF560SFYM 19.6 cu. ft. French Door Refrigerator SpillSaver Logo
Posted on Dec 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door alarm doesn't work
Alarm does not sound and icon does not light up
raj somaiya
Level 3:
  • Master 5,370 Answers
  • Posted on Dec 22, 2012
raj somaiya
Master
Level 3:
Answers
5370
Questions
0
Helped
3569228
Points
14579
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Trailblazer won't start
Open the door,when alarm goes off insert key into ignition and alarm should go off and it should start,try that.
Alarm won't turn off
the valet key doesnt have a transponder chip in it, so it will allow physical turning of keyways and operations, but will not disable the alarm and often wont disable the immobilizer.
sorry to say i think you will need to get an autolocksmith , or main dealer to get you a functioning key with transponder chip mapped to your cars rfid system that will allow alarm to be enabled /disabled
Freezer light doesn't work and door ajar alarm going off
The door switch is faulty. It switches the light on. There is no battery.
2answers
Alarm goes off with ignition on. Dash lights work so there is power but nothing at the starter motor
Sounds like the security system is armed. It is designed to disable the starter. If you don't have a key fob for the alarm, try locking and un-locking the driver's door with the key to disarm. If that doesn't work, look for a very small black button or toggle switch that will either be taped to wiring under the driver's side or the dash, or mounted to the very bottom of the dash above the driver's legs.
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
MY KEY DO NOT LOCK DOORS AND SET ALARM
I would try disconnecting the battery for five minutes like resetting a computer. Replace the battery in key fob. Body computer does strange things with lights hope it doesn't need to be replaced about 350 dollars if you have it replaced and any thing else doesn't work after they replace it tell them. I had two of them replaced for me because they are rebuilt
My 2000 hyundai tiburon alarmed itself and the alarm is sounding. I have no remote control that works.
Put key in ignition, turn all the way forward, but not trying to start. Let alarm cycle 2 times, when it stops the 2nd time, remove key and alarm should be disarmed. This will only work if it is a factory alarm.
Alarm went off had to disconnect battery to shut off, door open light stays on, interior light stays on door locks and window controls will not work
O.k. this is a security feature of your alarm the car now essentially thinks that it is being stolen. In order to fix this issue you need to reset the alarm buy reconnecting the battery and using your electronic alarm sensor if you have one (if this doesn't work get new battery for alarm sensor)
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
