The brother MFC all in one printer says "telephone" on the screen and won't work correctly
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
SOURCE: error 46 in brother mfc-440cn
Machine Error 46 ("Unable to Clean") indicates that the wasteink is full. Basicly it gives you two options - have it replaced (a semi-complicated performance which requires buying a spare part and change it yourself) or have it sent to service. If you do not have any warranty on the machine, the more suitable would probably be to just replace the machine instead, since it's relatively cheap compared to both service costs and having the wasteink replaced, but you instead get a full new warranty on your new machine.
Unfortunately, there's nothing you yourself can do to remove this error, without actually changing an item inside the machine.
SOURCE: how do I network brother mfc-440cn printer - what
SOURCE: I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
