Question about GPS
I have a Navigon 40 Premium that will no longer charge
    Top Expert:
  • 14,553 Answers
Its either the battery, the connection where charge is connected or the source for voltage.
If you use a cigarette lighter plug there is also a fuse inside that(since I do not know how you charge I suggest that)
Posted on Dec 21, 2012
6ya staff
SOURCE:
My tom tom started with the screen going dull and then volume went lower and it started to shut down then same thig happened a battery symbol of a rectangle shape with a little red section then sat n
can you connect it to your usb port on your computer? if so try to connect and use it. dont worry about charging it just use it to see if its working ok. i dont know why they put a battery that is not replaceable in those. you must send it back to them to replace, I keep mine on power all the time. check this out first and see if its a malfunction or works ok.
Jan 31, 2015 | Navitech TomTom / Tom Tom GPS / SatNav...
My navigon 40 easy does not turn on
check the power cable first
Jan 29, 2012 | GPS
My Navigon 2100 GPS lights like it's charging, but it won't turn on
I HAVE A 2100 NAVIGON GPS SCREEN WONT COME ON TRYED CHARGEING IT THE ORANGE LITE COMES ON /WONT CHANGE TO GREEN ALSO TRYED TO RESET NOTHING DO YOU HAVE ANY IDEAS WHAT ISHOULD DO NEXT .
Jun 30, 2011 | Navigon 2100 Max Portable GPS System
Navigon 7100 need activation code key for fresh maps
Activation cord is in the freshmaps activation card that comes with purchas of device.It is on the back of the card remove plastc with nail and you will get 15 digits number in 3block with 5 digits each.
May 05, 2010 | Navigon 7100 GPS Navigator GPS Receiver
How do I give my brand new Navigon 3300 a good overnight charge
if you have a pc, you can use the usb to mini jack and it will charge
Mar 09, 2010 | Navigon 3300 Max Car GPS Receiver
Navigon 2100 doesn't pick up any signal. Tried by keeping it on for more than an hour at various locations outside.
Nine minutes is the maximum time a GPS should take to lock on to a signal. Longer periods are caused by a failing battery or a battery that is not fully charged.
Either charge it via AC or USB, car chargers do not charge them fully they are just mainhtenance charging.
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | GPS
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Oct 23, 2008 | Panasonic Navigon 5100
GPS Logo
62 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
