SOURCE: Frigidaire electric dryer model # LEQ2152ESO runs
probably a loose connection on the speed control board
SOURCE: Frigidaire Gallery dryer only runs for 15 seconds
Try vacuuming the lint screen and slot. It worked for us.
I had encountered issues like your concern regarding the problem Frigidaire dryer. Most of them had contacted the Frigidaire repairman to check and put in a new control board and it works like brand new. Though it costs $100 for the service but this amount will be refunded if you contact the Electrolux and ask for a code to give unto the repairman to cover the cost of the board.
You may contact also:
Chris Polk
Escalation Specialist
Electrolux Major Appliances
[email protected]
So you may be guided, just send your contact information, and the best time to contact you. He would also need your model and serial number and a file number if available.
I hope it helps ^_^
Good morning friend, I appreciate your post!
I understand that your Frigidaire washer will start but after 30 seconds it will cut off and all your indicator lights will flash. It could possibly be a miscommunication with the board I would try to reset your appliance, you can do this by unplugging the power cord or flipping the household circuit breaker for ten minutes. Could you comment back I would like to verify if that helped? I look forward to your response. -Matt
