Other than a tech looking it over, look inside at the main and power board for green led lights on the board, they are used to indicate the voltages are there or not, a clue to what may be happening.
The other known issue is the power relay/s this set may have up to 3 and they are known to stick open or closed If the power light does not go out when the set is turned off one relay is stuck--simple test in any case is a gentle tape with the handle of a screwdriver on the relay/s.
this is a view of one upside down.
Please respond/ this actually works but I had to figure out what the hell u were actually talking about.so let me help u help others like me.What I mean is u gave me the right answer to fix my problem but the way u said "tape" I don't know if u meant tap but I had no tape so I tapped and it worked on the part that u describe so I would like to know if possible if this is the case or if I came up with another cheap fix....
