No. Lens can not be removed.
Ref: http://service.us.panasonic.com/OPERMANPDF/DMCFZ8.PDF
SOURCE: I've lost download software for my DMC-FZ8 [email protected]
Please ensure the drives are installed properly. You should be having these in the installation kit, that comes bundled with the camera. Then try downloading the images
(or)
Panasonic Lumix DMC-FZ8 stores images in an SD Type memory device. You can remove the SD memory out and insert it to a card reader. You can get it for as low as Rs 150. This is just an workaround.
SOURCE: Inoperative Panasonic Lumix DMC-FZ8
I had this issue and found a small grain of sand around the lens. On removing it the camera worked fine again.
SOURCE: Dropped my Panasonic Lumix DMC-FZ8 in a stream -
You cannot clean the inside of the lens. If it must be cleaned, it needs to be disassembled by a Panasonic service center, cleaned, reassembled and re-calibrated, and then returned to you at an enormous cost. You need to determine if it's worth it.
