To get the MEP Unlock code for Blackberry Curve 9300 you need to specify the IMEI Number,Network and country it is locked now.
Visit the site Theunlockspot.com get unlock code for Blackberry Curve 9300 and unlock it easily.
Dear:
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: MEP unlock code for blackberry 8350i
hi
you need unlock code to unlock your phone right ...........
dont worry you can get unlock code ......... fromthird party......... and by searching in google, and read several forums and i foundthis provider who provide remote unlock codes, the pre sales was excellent evenafter the purchase there customer support was a+, you can Get code fromhere................click here
SOURCE: Free Mep Code For Blackberry
The following are the steps all we need to take to unlock the code for BlackBerry Curve 8250/8520 if we happened to get our BlackBerry Curve 8250/8520 code locked.
Turn on the Blackberry Curve 8250/8520 with the current network/service provider's SIM card.
Using the menu, go to Settings Menu
SOURCE: need free mep code for blackberry curve?
It's a clear and fully detailed guide on how to unlock a BlackBerry Curve :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
SOURCE: serching for MEP code for blackberry curve 8520
Just follow instruction from this link and you will get your mep code by your own. That sites also selling blackberry curve 8520 unlock code for your phone, so if you want change your old sim card with another sim card from other network provider you can use that blackberry unlock code.
SOURCE: RIM BlackBerry Curve 3G 9300 mep code 0
There is one option left to unlock blackberry curve 3G 9300 if your mep counter attempt to 0, in this case blackberry unlock code will not affected anymore. You must doing cable unlocking process, this method will force your blackberry unlocked and you can do that at mobile repair shop.
