That usually means it isin pairing mode. Charging some headsets from extended periods can sometimes reset the device requiring you to pair the device again.
the problem seems to be the charging box. if the red light goes off relatively quickly after you place the bluetooth in the box then it is not gaining a charge. you have a warranty with this item that you can claim by following the instructions on the warranty card provided in the package.
1ST IT IS NOT A MOTOROLA PIECE. IF IT IS A MOTOROLA PIECE I APLOGIZE BUT I MAKE THE HFBLU-10K. IF ITS A CELLULAR INNOVATIONS HFBLU-10K YOU CAN EMAIL ME AT [email protected] AND I WILL SEND YOU A COPY OF THE MANUAL
i am the manufacturer of this unit and a car charger for this unit was never made. any car charger you may find and use with this item would be at your own risk and the item would no longer be warrantied by us.
yes, this item is definately compatible to the iphone. try this:
1) turn bluetooth unit completly off
2) make sure bluetooth function in your phone is turned on
3) from the off position hold down the (mfb) or power button as if you were turning on the unit
4) you will see a blue light indicating the btooth is powering on DO NOT LET GO OF BUTTON
5) after blue light you will see red and blue light start to flash together..when you have achieved this state you can let go of the button
6) go to your phones btooth menu and go to where it says add a device or search for devices(terminology different in every phone)
7) your phone should search and find it, it will come up as hfblu-10k.. after it finds it just follow the prompts your phone gives to complete the set-up. FYI password is "0000"
