Are you referring to the spark, or the gas flame? Are you able to turn the faulty burner on low, and lite with a match? You most likely need the spark switch replaced. Pleazer Appliance...
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills.. I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
that shouldnt matter u probably have a runner tube where the gas runs from burner to burner sometimes they get clogged or spiders can build webs in them ur best bet is to turn the gas off take apart and clean tat should solve ur problem
Yes you can, I am proud to own one i've had it for a yr and a half and it is better than the most of the top name external drives, i use to to copy to and from my pc..
It could be a bad regulator but,highly unlikely . Check your air shutters at the end of the burner tubes and adust them properly.And if you have a OPD propane tank you maybe turning it on to quick causing the check valve inside the gas valve to open half way. Try opening the valve slowly.
I must assume that the unit uses manual controls for the burners.....if the orifice feeding the burner is plugged (some sort of spill) the gas will not reach the burner for it to light. If it is just one burner, I would investigate a plugged orifice feeding that burner.....if it is all the top burners, there may be a supply problem. let me know what you find.
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
Turn you burner to the Lite position:
If you hear clicking or sparking, go to Step 2.
If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Clean the burner and electrode:
First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
Check to see if the burner works, If not, then go to Step 3.
Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
Check to see if the burner works, If not, then go to Step 4.
The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
