The car makes a squealing noise when running, drive belt looks good. Noise seems to get better when a/c is turned. Could it be the compressor going out?
SOURCE: squealing NOISE possibly from fan belt
There are several things you should know;
1. Power steering belt, when you make a turn, sometimes make noise, because your car needs power steering oil,=transmission oil.
2. when you turn on AC then you can hear a loud noise, you must check AC compasser,If the head wheel frozen, it will make a lot noise, that you have to fix your AC compasser.
3.check these two first, if both ok. shot some wd40 or lubricate see if it's work.
Hope this can help you
SOURCE: squeal which sounds like it's underneath the car.
Do you know if he turned the rotors when brakes were done?
SOURCE: Squealing noise whilst driving
it is the backing plate for your brakes. you need to take it to the shop and make them fix and not charge you. as it is their fault that it happend.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
