SOURCE: standby light blinks twice approx every 2-3 seconds tv won't turn on
Visit this site 'Electro-help" for details. Type in the site name either to Google or Yahoo search box, and click search. It has all details about tthis fault, and repair.
SOURCE: tv wont turn on
well first of all if anything happens when you push the button then the button works! I think you should leave this one to a professional technician. There is a circuit problem that will require advanced knowledge.
SOURCE: TV won't turn on with
The flashing timer light blinks out a code, where it flashes some number of times, pauses, then repeats. The code indicates what fault is keeping the set from coming on. Unfortunately, all the codes tend to mean that there is some electronic problem with the TV. Unless you have some electronic servicing skills and the necessary equipment to troubleshoot the problem, you'll need to have set checked by a professional. For any code there can be many causes, so I can't offer any other advice.
This might be a good time to check sale prices on LCD sets. Let a technician check the set and give an estimate for the repair, then decide.
SOURCE: Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
