Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
Posted on Dec 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to I increase the temperature to 101 on the drreammaker spa fantasy model?
I don't know which buttons or what to hold down to get the temperature to go up. It is staying at 96 degrees.
Mike Tellegen
Level 3:
  • Dream Maker ... Master 1,631 Answers
  • Posted on Dec 28, 2012
Mike Tellegen
Level 3:
Answers
1631
Questions
Helped
1012371
Points
5840
This may be a little late as you may have already found the answer. But most "Fantasy" spas have "Balboa" control system. They are either a heat control knob, or Up/Down arrows on the spa side control system.
If you have the know & it is all the way turned to max position, and still not hot enough, then you may well have a faulty "Temperature Sensor". Get a replacement from your local DreamMaker dealership. Easy to replace.
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Nov 01, 2009
SOURCE: we have a dreammaker spa, how do we drain it? the
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
john224
John Prohaska
  • 1378 Answers
  • Posted on Oct 12, 2010
SOURCE: breaker on the end of
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
1helpful
How do I get my fantasy spa out of ec mode and into st mode
Try:
  • Push either up or down arrow to make the display show "Set" temperature
  • Then push "Mode" or "Light" button.
  • This will toggle the filtration/heating settings between Ec, St, and Slp.
    • You will have to do the above each time to go to next Mode.
  • If the above does not work, then try pushing the Jets button instead of Mode/Light button.
Nov 23, 2014 • Pool & Spa
Tempature keeps dropping down to 59 will not hold it temp at 101
If your spa will not maintain the temperature it is set at, the most common problem is going to be the temp sensor.
Once you replace the temp sensor you should find your temperature regulated as it normally is.
Rod
US Parts Center
Mar 16, 2014 • Home
Display locked up on Coleman spa with bolboa instrument panel
Depending on which control system your Colman has:
Try these:
Press & Hold the JET Button for 6 seconds (Most/Gecko & Hydro-Quip)
or
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position.
Hope that helps
Nov 03, 2012 • Pool & Spa
Cannot get temperature buttons on hot tub to change
Do the other buttons work? Is the control panel locked, some spas have a control panel lock to prevent kids from playing with the temperature. Are any of the buttons stuck in the de-pressed/down position? If neither the problem is likely in your topside control which means it will need to be replaced.
Sep 18, 2012 • Pool & Spa
2helpful
Light keeps flashing in spa
Sounds like control panel failure or the keypad is locked/stuck.
Try hold temperature UP & DOWN together for 6 seconds.
or if you have a Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
As your lights are flashing the button might be stuck in the down position.
My pacific hot tub has LOC on the display and i cant adjust the jets or temp. Is the display locked and how do i unlock it?
Mike,
Yes LOC is a standard topside lock code.
Try these common unlock codes,
Press & Hold Jet Button for 6 seconds
or
Press & Hold Temp Up & Temp down for 6 seconds.
Possibly your jet button is faulty i.e. it is broken internally or when it is pressed the button sticks in the on position and locks out the panel.
If those common codes don't work let me know which brand/topside control your spa has and I will get a more specific answer.
Jan 16, 2012 • Pool & Spa
Topside control issues
Topside control is in "Locked" mode.
If you accidentally locked your control
or
or
If these do not help let us know your control make and model & we'll see what we can do to find out more for you.
Unlock control panel
or
or
Top Dream Maker Spas Pool & Spa Experts
john h
Mike Cairns
Mike Cairns
goneforever.
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
