Door Won't Open and washer wont run any cycles.
I got this problem to, I’ve replaced lock, wiring and main power board. Checked everything over and over again, it’s also tripping power occasionally, what next?
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
SOURCE: Electrolux front load washer door won't
First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
To do it, turn
off power, unplug at the mains. Drag the machine out so you can see
the back. Remove the 2 screws that hold the top on, pull back or tap
the top forward (depending on the model) to unclip it. Peer inside.
You will see the door switch inside the chassis exactly in line with the
door handle on the outside. See if you manually make the mechanism
release, or if you have a stubby philips screwdriver, you can probably
unscrew the switch complely.
Keep us updated.
SOURCE: Electrolux EWF1087. door locked shut. when i reset
sounds like door lock is faulty e42 is saying door is still open. could be wiring to door lock also.
SOURCE: Electrolux Eco Valve EWF1087 washing machine,will
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
