Question about Avaya 9508 Digital Deskphone - digital phone
Message indicator When I receive a vm, sometimes the message is lit and other times not. ????
    New Friend:
  • 26 Answers
The Message Waiting indicator light is typically a notification pushed from your PBX to your phone, as your voicemail does not actually reside on your phone, but rather centrally on your PBX system itself. If you are not always getting MW indications on your phone, it could be an issue with your PBX/Extension configuration. I would check with whomever set up your phone system and have them take a look at the configuration on the PBX for your particular extensions.
Cisco CP-PWR-CUBE
Posted on Dec 19, 2012
6ya staff
SOURCE:
2006 chevy trailblazer is not charging battery. battery and alt are new
Volts slowly drop to where what quits ,The vehicle stops running ? Is the charge indicator light lit on the instrument cluster /? are any lights lit on the instrument cluster ? The instrument panel cluster (IPC) illuminates the charge indicator and the BATTERY NOT CHARGING message is displayed in the message center when the following occurs:
The engine control module (ECM)/powertrain control module (PCM) detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a serial data message from the ECM/PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a serial data message from the body control module (BCM) indicating the system voltage.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
The ignition is on, with the engine off
Mar 11, 2015 | 2006 Chevrolet Trailblazer
Panasonic kx-tg6441 no message light
Please ensure the VM Tone Detection feature is turned on by pressing the [MENU] button, then [#], 3, 3, 2, choose "On" and then press the [SAVE] button.
Mar 04, 2014 | Panasonic KX TG6441 Phone
We had a phone where the message light wasnt coming on. I found the fix but now the light is on when a message is left but where I did the fix when you pick up that phone (with prob) receiver then hit the...
Here's the free, don't look in the manual, free answer. You didn't fix anything, you set a message waiting from another phone. Either answer the other phone when you press the MESSAGE button, or dial 700 plus your extension to clear all MW lights. When you first press message, without picking up the handset, look at the display. It will tell you who, or what, left the message.
I don't know why you're using 167 as it's the 3rd set of VM ports, but the VM system needs to send out the MW indications. You can tell the system in 990 to let the VM or the phone system to cancel the MW light.
Carl
Aug 29, 2011 | Panasonic KX-T7433B Corded Phone
The VM is lit on my phone all the time even though i have no messages, how can i clear this?
if the phone is an AAstra phone model 9116 (look on the underneith) then hit Options then down arrow (under the viewer) to the indicator message then hit delete and then save
if it is a 9216 or 9316 model then slide the little bar(under the view glass to the right and hit the button under the slide and down arrow to option 4 and hit the 4 button and turn of the indicator. it will work properly imediately and resume as it should..
to prevent this , after you listen to your messages hit the * button twice before you exit your voicemail system
Jan 18, 2010 | Uniden DECT 6.0 Cordless Telephone...
My voicemail indicator message lamp stays on.
What voicemail do you have?
Vm Pro or embedded?
If voicemail pro, you will need to navigate to the folder where your messages are stored on the pc, delete them, then stop/restart the vmpro services. If you dont know what I am talking about, I would call someone in that is a knowledgeable tech....
Oct 21, 2009 | Avaya 5400 Series 5410 Phone
We have the Norstar Meridian (M7310)telephone system in our non-profit organization. Recently there was a change in our service providers and since that time we have had nothing but problems with our...
Could be two things, there could be a general delivery mailbox attached to the system which is mail box 100, or the new service provider has a off premisis voicemail attached to the lines. if there is VM on the lines you should get a stuttered dial tone on the line indicating that you have a voice mail.
Oct 13, 2009 | NorStar M7310 Corded Phone
VM light on but no VM message
Have you ck'd the general delivery mailbox 100 sometimes a phone is set to light the vm light on your own box and gen del mbox. Also there is a send message feature which sends a text from another station. Ck to see if your display has any message indication you can ck and maybe call back the station that sent it to cancel.
Good luck and let me know if this helps.
Aug 04, 2009 | NorStar T7316E Corded Phone
VM light indicator will not stop blinking
hmmmm perhaps it may be the phone it self
Jul 31, 2009 | Lands Phones
Avaya 9508 Digital Deskphone - digital phone Logo
439 people viewed this question
Top Avaya Computers & Internet Experts
Thomas F. Schneider
Vincent G
Vincent G
Duncan Mutch
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
