SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: hi i have a samsung
The only way to get around this is run the recovery
How to do this
1. Turn off the phone
2. Told down the UP Volume button and power button
3. Wait till the screen comes on and then off
4. A menu shows up and click restore/recover
5. The password is gone.
SOURCE: describe how to unlock my
easy as pie download android sdk from google install it on your c drive under android sdk then download and install the usb drivers for your phone then right-click on "my computer" on your pc select properties select environmental variables highlight path select edit and ad in c:\androidsdk/adb/tools then plug in your phone to the pc open a command prompt via the run function on your start window and enter: command then type in "adb" press enter then type in "adb" devices then press enter at this point you can unlock your phone via an adb command listed in the command promps once you type "adb" then press enter ill link a youtube video its not as hard as it sounds its just not the easyest thing to walk a person through with a written discription. if you still dont feel upto it pay someone on craigslist 10 or 20 bucks to do it for you they will offer you the option to root your device witch is awsome but more dangerious or annoying than 90% of android users. sorry for the long explanation. here is your youtube link
SOURCE: my samsung galaxy ace is
More than likely, you will need to reset your password for your GMail to get back into your phone. Go to Google.com to reset your information.
If you are unable to do this, you will need to do a Factory Restore to your phone. WARNING: Factory Restore will erase all phone data. It will restore the phone back to the stage when you first purchased it.
To restore your phone back to factory settings do the following:
1. Power down the phone.
2. Hold the Volume Down button and press the power button.
3. A menu pops up, release the Volume Down button.
4. Press and release the volume down button to select "Clear Storage"
5. Next, Press and release the power button
6. To confirm, press the Volume Up button
The phone will run some tasks and then reboot. You may then signin with a new Gmail account. I suggest recording your new account information in a safe location for future reference.
