Recently wiped out my Lexmark program have reinstalled from lexmark on line however since i reinstalled lexmark only works with a UBS cable attached & only prints won't scan. I have always used it on wireless in the house now it won't connect, my macbook says printer not connected. My other pc has attached to the printer & works on wireless without incident it is only the mac I can't get to reconnect. I need help please.
SOURCE: Error Scanning from All-In-One to Vista
This appears to be a Vista driver software issue- check out Lexmark for any updates
You can also try the followng.
go to--- Start/Programs/Accessories/system Tools/Compatibility Wizard and try resetting the machine to run as XP
SOURCE: Is the Lexmark X2350 printer compatable with mac osx?
You will need a emulator for this and can be downloaded on the internet otherwise there is no mac driver and its not really compatable and its a older lexmark printer so the only solution is emulation Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Can't print from MacBook, through Time Capsule, to Lexmark x5470
turn on the printer sharing via the system preference panel on the computer that is on the system via usb.
Then on your wifi computer look for shared printers and you'll see your printer in the list under the host computer name... use that setting and it should fire up for you!
let me know how it goes...
SOURCE: Lexmark X6570 Wireless Printer not working on Mac
There is still something to be done in the driver section on the Mac. It has to be completely uninstall and then install. Before you uninstall, recheck the driver settings.
SOURCE: Lexmark 2600 scanning to MAC-no can do
Edward, I have this same problem. Were you able to solve it? Anyone, can you help? I have installed the drivers. When I connect the printer to my Mac, it launches ImageCapture and previews the scan fine. But I am unable to get the "scan" button to become active, adn there is no place to save the scan. If I click "save pdf to iphoto" it saves a pdf of the entire screen, rather than just the photo. Appears not to be Mac compatible for scanning purposes. Thank you for your help.
For more detailed instructions on how to use your printer, please refer to the Lexmark X6650 User's Guide.
Print the network
settings page to identify if your printer is connected to your wireless
network:
1. Press Setup on
the printer operator panel.
2. Press the right or left arrow button until Network
Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now
print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address.
SSID should be the name of your wireless network. Otherwise, you may need to
reset the printer's wireless network settings.
How to
reset network settings:
1. Press Setup.
3. Press the right or left
arrow button until Reset Network Adapter Defaults is
4. Press the right or left arrow button to display Yes,
pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark
Wireless Setup Assistant on your Mac.
