Dishwasher stops with second and third lights flashing
SOURCE: indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
SOURCE: Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
SOURCE: green flashing lights , what does it mean ?
I have an Indesit IDL 500, the machine will start fine but after about 20 mins the Ist and 2nd button start flashing. Can you help?
Regards
Ingrid Houben
SOURCE: Hi, our Indesit IDL500 dishwasher has stopped
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
