Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as the free Picasa.
SOURCE: Kodak EasyShare C633 6.1 Megapixel digital camera. want turn on
maybe it needs new batteries..my camera does this but when it needs batteries...i'm thinking of getting a new digital camera because i have to buy batteries for it every week no matter if they're lithium or rechargable...so don't know if this is the problem but hope i could help some..
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
SOURCE: looking for manual for Kodak EasyShare C913 digital camera
Hey
theres a online user manual available here
http://www.kodak.com/global/en/service/publications/urg00898toc.jhtml?pq-path=13177
or heres a extended user manual with more content
http://www.kodak.com/global/en/service/publications/urg00897toc.jhtml?pq-path=13176/13178
SOURCE: Problem for Kodak EasyShare One Digital Camera
check device manager to check if the camera is detected properly when connected via USB, try deleting the camera device then reconnect the camera and the drivers should re-install. hopefully you should then be able to transfer images from the camera.
if this fails try using a memory card reader instead of transferring directly from the camera.
