The machine now has stop working. I am not sure if the battery needs to be charged or is something else wrong. Now that it has stopped working, when I hold the trigger the battery light flashes?
Very interesting topic
This doesn't address the intermittent power cut offs...power cuts off intermittently and you have to keep recycling the power 'trigger' to get it to work...total PIA
Just had the same problem with mine, turned out to be the seal along the top of the collection pot being blocked up so much the seal wasn't sealing properly stopping the vacuum from being created, once it popped and a vacuum was created it worked again, I suggest a good clean up of all compartments to try to get it working again, as it sounds like it's struggling to create a vacuum properly
OMG THANK YOU!!!
you saved me so much aggravation, this has been going on for a year
SOURCE: dyson not working
I suggest you check the hepa filter for black soot. If it is black and yucky then the motor is probably burnt out. Check out the guide at www.tasweb.org for instructions on how to fix it.
SOURCE: dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
SOURCE: whistling noise on dc25 Animal
there may be a small cut in the tube or there is something stuck restricting the suction check all hoses
SOURCE: Dc 31 animal: even when
Sorry to hear you're having difficulties with your DC31 Animal. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone with you to identify the cause of the issue. They'll be happy to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
