Radio Shack Pro-84 Handheld Scanner Logo
A
Anonymous Posted on Dec 17, 2012
Pro 404 scanner master reset - Radio Shack Pro-84 Handheld Scanner
1 Related Answer
Anonymous
  • Posted on Aug 02, 2011
SOURCE: codes for a radio shack pro 404 scanner
How can I clear the message ALL ch L-O???
How can i make the battery holder in a pro 404 ton charge batteries
I suggest NOT charging any batteries in any scanner- it gets too warm. Charge your batteries in a stand-alone battery charger is my suggestion. okay?
What is the four digit code for my pro 404 scanner
I plugged a 1/8 phono plug in the PC/IF jack over and over repeatedly and this fixed mine.
2answers
Codes for a radio shack pro 404 scanner
Codes? If it's frequencies that you're looking for, you can find a comprehensive database, and a lot of other useful scanning information, by visiting:
www.RadioReference.com
Bill B.
Listening in since the 60's
5helpful
Need to do a master reset on pro 84 sanner but don't have manual
To RESET the PRO-84, turn the scanner OFF, then hold in the 2, 9 and HOLD keys and power the scanner ON. The word CLEAr will appear on the display to confirm the RESET.
While the manual for the PRO-84 has not been posted by Radio Shack, it is essentially a red PRO-83. You can download/print the 83 manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
How do I do a master reset on the pro 83 scanner
To reset the scanner (clear a problem or keyboard lockup):
- Tune the power OFF and then back ON.
- Insert a pointed object (paper clip, ballpoint pen tip, etc) into the RESET opening on the side of the scanner and gently press the button inside.
If the RESET does not clear the problem you can INITIALIZE the scanner, but this procedure will clear/erase all information that you have programmed into the scanner.
- Power the scanner OFF and then ON.
- Press and hold the TUNE/CLEAR button while pressing the reset button as above. The display will momentarily blank.
- When the display resumes, press TUNE/CLEAR again.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
BillB
2answers
Connection
Hi...there,
Try Red, Green, Blue that is a sequence. settings all to 100% Have a nice day!
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
