SOURCE: HP 1020 connected to DPR-1260 does not print. Same
configure static ip on print sever or printer
SOURCE: HP laserjet P1005
Go to the printer properties, you can go from Start-->Printers and Faxes. Select the printer (it should say something like, HP LaserJet P1005 on DPR1260 ..... make a double click on there. Then select Printer -----> Properties. Then go to Ports, and DE-SELECT the box that says: Enable bydirectional compatibility. IT SHOULD BE NOT SELECTED. Then Select Apply, and then Acept. After doing this, the printer should start working.
SOURCE: Have got a dlink DPR-1020 print server limked to a
please re-install print server and printer
SOURCE: what is the difference between
One of the main difference between this tow printer is the DPR1020 is made to work with all printer including those multi function printers , because this old DP301U was a older version of print server that don't support those new multi function printers features like scanning and fax. So if you have a multi function printer I will advice you to get the DPR1020 so all features of that printer will work behind this print server.
