Okay this blackberry messenger would not recieve photos that bbm contacts send them it also says that incoming transfer files canceled built in media and i tried to off the mass storage button in settings and options but the error keeps appearing when files are sent what are the options that can be use to fix this problem
SOURCE: cant receive files via bluetooth, cant transfer files from comp
go on to your media then music, and press the blackberry button and recive a file should come up then do it like that.
SOURCE: Phone Book Transfer Nokia N70 - Blackberry 9000
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need:
1. Computer
2. Nokia N70
3. Black Berry phone
4. Nokia PC Suite CD
5. Black Berry sync software
How:
1. Install the Nokia PC suite to the computer.
2. Connect the Nokia N70 to the computer.
3. Export all the Contacts from Nokia N70 to your computer (refer to the manual)
4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry.
5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
SOURCE: how can I change keypad
hello you can try setting it by using and holding down the a key on the phone. THE newest software should have change that for you .
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
