It just began to stay open the other day. Since it won't stay closed, the light stays on all the time. Please help!
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
SOURCE: Door Won't Close
What usually breaks is the door open lever, but sometimes there's just a grease buildup around the door open button.
On
a counter top model, the outer cover will need to be removed to
diagnose and repair this. On an over-the-range model, only the control
panel needs to be removed.
Please unplug the oven first.
If
you or someone you know wants to look into this, we have critical
safety, disassembly, and troubleshooting info at our site, and our link
is at our listing here on FixYa.
Once
it is apart, you'll be able to see how the door open button would press
against the door open lever, which would then lift up against the door
latch heads (hook-like projections on the door) and the door should
open.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's a Sharp or Kenmore, you can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you still have trouble, please reply back with your model number so we can help you.
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your
full model number) for more information & help.
We're
William E. Miller
[email protected]
SOURCE: Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
SOURCE: Whirlpool Gold Accubake system microwave indicates
I just had the same problem with my microwave. First DISCONNECT THE POWER. Remove the front top grill (screws are on top of microwave). Unscrew the one screw at the top of the control panel and lift it out of the way. You will see three micro switches to the left of the pannel. I bent the metal frame they were mounted to by hand to move them back into place. The microwave oven works great now. If this does not help, then I would consider replacing the top limit switch.
