Try with another sim card, clean the sim connector of your phone, reset you phone to Factory Setting (default) using 12345. If you can open it, clean the mobile thoroughly using IPA solution. This problem is caused by Firmware problem and Hardware problem as well. Good luck.
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
RAZR v3m is not compatible with T-Mobile, as it is a CDMA phone, used on services such as Verizon, Sprint, Cricket, etc. The v3m is not a GSM phone and does not have a SIM card, and therefore cannot be used on GSM services such as T-Mobile and AT&T (Cingular).
T-Mobile does have a RAZR v3, but it is not a v3m. The v3m is similar to the v3s, which is also a CDMA phone, but adds a micro SD card to store music and photos on.
