Simple answer is that the Laser Assy (ie. Scanner) has gone bad. It is a sealed pack inside the printer that housed the laser and octagonal scan mirror (it spins at very high speed) and if there is any issue with the motor or the laser sensing device it will throw that code. Depending on your cost/value proposition of the printer will determine wether or not you want to spring for the replacement of a new scanner. Labor and Scanner cost will probably run $300-400 would be my guess. If you find a repair facility that will replace the scanner with a refurbished scanner you can shave about 40% off the price of that. Your labor cost should be 75-100 per hour and is about an 1.5 hours to do the work. Good Luck
