sry the HDD was bad, its too bad cause it was a 500 GB HDD. I put another one in and put vista on it and now everything is AOK.sry the HDD was bad, its too bad cause it was a 500 GB HDD. I put another one in and put vista on it and now everything is AOK.
Sorry to hear that, glad you solved you issue. Machines break, usually at the worst moment.Sorry to hear that, glad you solved you issue. Machines break, usually at the worst moment.
You can't post conmments that contain an email address.
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Yes, this sounds like the traditional black screen issue, but it's
different! This machine is a Dell Dimension 3000 with XP. System won't
boot. After Blue Dell BIOS splash screen with F2 & F12 options, it
just goes black. There will ultimately be a white cursor in the upper
left hand corner. I can edit BIOS with F2, I can get in to the boot
menu with F12, but I can't do anything after that. I can even get in to
the Safe Mode menu (F8), but it never boots.
Hi, maybe you can take a try of this rescue program called PowerSuite Golden. I came across similar blue screen situaiton on my HP laptop (win 7) and it helped me get rid of it and rescued my data back. It is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all. Hope it helps in your situation too. Regards
PowerSuite Golden is the right software you need in your case, it is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Download
the ISO file----> Burn it to CD----> Boot your PC from the CD by
setting the CD drive as the first boot device in the boot sequence.
Hi, maybe you can take a try of this rescue program called BootSuite. I came across similar blue screen situaiton on my HP laptop (win 7) and it helped me get rid of it and rescued my data back. It is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all. Good luck.
