LG Bp325 3D Slim Smart BRay Player - Black Logo
Anonymous Posted on Dec 17, 2012
I want to make my LG BP325 Blu ray/DVD player region free
I have whole series on DVD from the US and the UK which I am no longer able to play on my new Blu ray/DVD player and I would like to know how to unlock the region code on it and make it region free.
  • Anonymous Dec 18, 2012
    I couldn't find a hack code for my make and model player.
Nanny
Level 3:
Genius:
  • LG Master 2,351 Answers
  • Posted on Dec 05, 2019
Nanny
LG Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989360
Points
7262
Many commercial DVDs are equipped with Region Code technology to protect its copyright, with the result that DVDs can only be played on DVD players with the same region code.
I suggest get region free player on your pc for free so that you can play region-locked DVD discs. You could try Leawo Blu-ray Player which is a region free, Blu-ray player.
Anonymous
Level 3:
  • LG Master 32,281 Answers
  • Posted on Dec 18, 2012
Anonymous
LG Master
Level 3:
Answers
32281
Questions
Helped
7913222
Points
102259
3 Related Answers
Anonymous
  • 273 Answers
  • Posted on Dec 31, 2009
SOURCE: Just installed an LG Electronics CT10N Slim SATA
Was going to leave this question? Normally computer will react that way when a blank disk that is not formatted is put into the drive. The blank disk then requires formatting and will function. Not sure if this answers your quesiton. Sorry.
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Dec 27, 2010
SOURCE: Is LG dvd writter play and burn the blu ray disc
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Anonymous
  • 3587 Answers
  • Posted on Mar 23, 2008
SOURCE: dvd-rom drive lg gdr-8612b software
ok...well...what computer are you using? you may find those drivers here, among the six we support
2answers
How do you change my region B Blu-ray player to play region A Blu-ray's?
Welcome to Epson Support for the I linked you to the manual and I also have LG support number: 800 243 0000. Thank you Jake and good luck.
2answers
How do i unlock my LG BH7520 blue ray dvd player to play multi region or region 2 thank you
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your player(region free). However, some DVDs (multi region in particular) will not play, since they require region detection from the player unit.
3answers
Have an LG BH7520 player and cant play my region 2 dvd movies
3. Press PLAY again
3answers
Hi have just bought a panasonic blu ray player model dmp-bd77 here in australia we have put in a b/ray dvd from the usa that plays perfectly but when we have put in another american dvd(not blu ray a...
Every blu ray or dvd player sold in the world comes as standard unlocked to play any disc from any region. On the fifth play of a disc the DVD or Bluray will become locked to that region. So if you play 5 USA dvd's on the player after the fifth disc has been played only US dvd's will be recognised by the player, Same applies to BLUrays. So if i were you i would be careful about what discs you are putting in the player. Otherwise you will be left with a bluray player that cannot be used in Australia. After that happens the only way to play other region discs would be to get the player unlocked. Another point to add , a blueray player has two lasers one to play bluray and another to play DVD's. Lasers can fail so you could be able to play DVD's but not Bluray or vice versa depending on which laser has failed.
2answers
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
