My Belkin is not allowing my XP wireless desktop PC connect.
I recieve limited or no connectivity, all the other (3) computers can connect. The desktop does not have a static IP, it's brand new and worked previously with my old router.
The wireless security on your router might be enabled.
1. In the address bar of your Internet browser, type "192.168.2.1". Then press the "Enter" key.
2. It will prompt for a password to access the Router’s Web-Based Advanced User Interface. By default the password is blank.
3. Go to Security, then Wireless.
- Check the wireless security settings, this should match the settings on your wireless computer.
4.
On the wireless computer, you should detect SSID and if wireless
security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
1.
Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect
the power plug into the router, yet. Make sure your computer is turned off.
2.
Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet
cable from your PC and insert it into the wireless G router's WAN port. You
should have an additional Ethernet cable that came with your router. Take this
cable and plug one end into one of the LAN ports on the router. Then connect
the other end to your PC's Ethernet port.
3.
Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately
30 seconds for the modem to boot up. Connect the power plug adapter to the
router and the other end into a power strip or outlet. Like the modem, it'll
take about 30 seconds for the router to boot. Turn on your PC.
4.
Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN
light. If you don't see any of them lit, confirm these devices are turned on.
Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router.
Set up features, such as creating your password and setting up your time zone.
Continue to follow the setup wizard so you can configure ?other settings
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
I have the same issue. I also receive the limityed or no connectivity error!!! I'm using DHCP, and while if I assign a static Ip address, it'll show connected, it doesn't produce the internet.
Have you tried changing the channel?
