Had this screen for a little over a year. On boot-up, power light flickers weakly and screen remains blank for some time. Eventually (after 10 or 15 mins) it displays like a sheet of white paper. Powering off and on at this point, the screen reveals a weak image of what should be appearing and then dissolves back to white. After about an hour in this state, the screen will, after a further power on and off, resume normal operation. Functions perfectly until being switched off at the end of the day.
Change capacitors c10 and c11 on inverter board (both 100uf 25volt)
Could possibly be a problem with the capacitors on the power supply board of the unit.
The solution that worked for me can be found here:
http://www.fixya.com/support/t145392-white_screen_xerox_xa7_19i
It a hardware thing
Try this test: put your PC into hibernate mode after the event of ..."After about an hour in this state, the screen will, after a further power on and off, resume normal operation. Functions perfectly...". Then force a hibernate state (START-SHUT DOWN-hold shift while hover STANDBY). Now, while in hibernate state, force a "resume Windows" state (space-bar on my PC). Any change on display to note? Hoping you answer yes, it is better now. If so, then continue with hibernate mode.
