If I have the same one; all you need to do is tune into the station you want to listen to. Then tap and hold on the preset you want to program it to. You will then see the p1 -p6 icon, which ever one you are programing will light up to indicate that you have set it. Its a little hard to see but if you have finger nails, the radio responds better. So in theory use a stylis when doing this it will be easier and much better to see.
Make sure your SD Card is inserted in the GPS SD card slot properly. it is located behind the head of the unit( where you insert your DVDs) usually has red or orange tape over it. just remove it and reinstall it. Hope this helps.
Click start>control panel> system> hardware tab> device manager. Check to see if under networking is your bluetooth adapter installed correctly. If you dont see anything labled bluetooth that means you dont have a bluetooth adapter installed. If theres a yellow mark next to the bluetooth adapter, that means you'd need to reinstall the drivers to get it working properly
No there isnt but you can get the info off via the data transfere cable But you must have external memory installed Aslo you cannot transfere photos directly to iphoto Your mac will see your KU 990 as just another external memory device
