Roland Boss BR-800 Digital Recorder Logo
Anonymous Posted on Dec 16, 2012
Boss br 800 driver windows 7
The Windows 7 Drivers do not install correctly.
Anonymous
Level 3:
Genius:
  • Master 1,212 Answers
  • Posted on Dec 17, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1212
Questions
0
Helped
469111
Points
2874
Uninstall any HP device and try it. Then reinstall the HP device.
  • Anonymous Dec 17, 2012
    Thanks, John! Tried it, but it didn't work. Keeps going through this uninstall process even though the driver is not apparent. I'm on an HP computer and removed the HP printer driver and tried it again: same result.
2answers
How can I Import and export voices from or to Yamaha DGX 640 from my PC running with Windows 10 ?
ask yamaha this, direct to them or read the manual firsts. 2010 made.
lost the manual ? did you?????
any app you run most be from maker yamaha for w10.
Yamaha DGX-640 88-Key Portable Digital Grand Piano with Weight-Graded Hammer Action.all there is , is here
yam
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=640
https://usa.yamaha.com/files/download/other_assets/2/314552/dgx640_en_om_a0.pdf
i guess you talking about what page 15 states.
then page 97 how to do it>?
what it can do is all there song file wise.
it shows w7 max.
but some apps w7 sure can be loaded to w10 or drivers
using windows 10
w7 compatibility mode as MS tells you.
seen here.
windows 10 32bit or 64 I see this too
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=DGX
try these?
1helpful
Is it possible to connect my Boss multiple effects ME-25 to my BR-800 recorder. If so how, and can it then be linked to an amp (again how)
Hi
I have found manuals for both and looking at these I can see no reason why they shouldn't connect to each other. I am not a music expert but deal with computers. I would suggest that you try the external amp connection to connect the ME-25 to one of the BR-800's inputs, and then connect the "line out" of the BR-800 to an amp. Also make sure that during the connection operation, all power to the four units is OFF and the levels are all set to zero. By doing this you can minimize any danger of overloads anywhere in the system when you do "Power on". To help you confirm what I have said, I give below the links to the manuals which can be downloaded in pdf format and saved to your computer for reference as you connect up, and for any queries in the future;
ME-25 Multi-Effects :- http://cmstest.roland.co.uk/assets/media/pdf/ME-25_egfispd01.pdf
BR-800 Recorder :- http://lib.roland.co.jp/support/en/manuals/res/39599043/BR-800_e04.pdf
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 • Boss Music
CTK810 smf converter fow windows 7
You need to get latest USB driver for Windows 7 (both 32bits and 64 bits available) at:
http://support.casio.com/en/support/download.php?cid=008&pid=20
I think the SMF converter though is a 32 bits application will work on windows 7 provided the correct USB driver has been installed.
2helpful
Windows 7 roland e 09 Can't connect to PC
go to the manufacturers web site and download the driver software for your pc version (mac os, 32 bit 64 bit) windows 32 bit osor 64 os you will find the drivers on theyre support page
Can't download tracks from BR-800 to laptop
Go to this site:
http://www.vsplanet.com/ubbthreads/
In the forums tab, scroll down to the BR8 forums. There is software to convert the BR files to PC readable. You can find discussion there of where and what to get.
How do i transfer music from my Computer to my
Page 2 of the Turbostart manual explains that in some versions of Windows the Micro BR may appear as a removable storage device titled "Removable disk (?:)." The manual is here:http://cms.rolandus.com/assets/media/pdf/MICROBRts.pdf It also mentions free downloadable wave converter software. Hope this helps.
2helpful
I have boss micro br hooked up to my computer it has windows vista.I'm not finding a micro br icon to click on to open files or drag to another file to open so as to send in email.
You won't find a specific Micro Br Icon since it is a data transfer connection only.
Try going to "My computer" and it should appear similar to when you plug in a USB stick. It MIGHT have a meaningful name, but it might not.
My computer doesn't recognize my boss micro br.
Have you installed the correct codec for it? Go to Microsoft site or Boss.com and download the codec and driver for it.
Good Luck
1helpful
When plugging micro br into the computer via a usb port, the micro br shows "usb connecting.." but nothing shows up on my computer.
Are there any drivers that need to be installed...possibly......you can generally find most answers @ the product website...you may have to register your product...maybe not.........it my just show up as another drive (IE: drive C:,D:)......
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
