The screen comes on and get blank
SOURCE: westinghouse 32 inch screen goes blank
I had the exact same problem and I fixed my Westinghouse 32 inch by replacing the power supply. You can purchase it at
http://www.partstore.com/Part/Westinghouse+Digital+Electroni/Westinghouse+Digital/4900211680/New.aspx?ModelMfgName=Westinghouse+Digital+Electroni&ModelBrandName=Westinghouse+Digital&ModelNumber=LTV32W1
I takes about 15 minutest to replace. Just take the back lower panel off and replace the power supply. Mine works like new now.
SOURCE: Westinghouse LCD TV freeze
I have the same problem ..... i just give it a good whack on the top of screen and the picture comes back.
SOURCE: westinghouse sk19h210s won't power on. service
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
SOURCE: westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
