Canon PowerShot A1100 IS Digital Camera Logo
Prabir Kumar Samanta Posted on Dec 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display not showing while taking photo
The camera is not showing the picture at the time of taking photograph
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Dec 16, 2012
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1195836
Points
12483
Press the DISP or DISPLAY button on the back of your camera. This button turns the LCD screen on and off to save battery power. You would then use the "peep hole" (optical display finder) in its place.
5 Related Answers
t00nz
CameraR
  • 4738 Answers
  • Posted on Apr 21, 2008
SOURCE: cannot take pictures
Sounds like you might be in luck. These symptoms sound very much like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Anonymous
  • 4 Answers
  • Posted on Aug 19, 2009
SOURCE: Can't get a picture on the screen - just shows
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
t00nz
CameraR
  • 4738 Answers
  • Posted on Nov 10, 2009
SOURCE: My A540 clicks like it takes a picture but nothing
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
But if you do notice shutter movement, then this would then likely be a CCD imager failure. It would in that case require Canon service to repair (1-800-OK-CANON).
Testimonial: "No shutter movement. I'll call Canon and see what's up."
Anonymous
  • 11967 Answers
  • Posted on Jan 23, 2010
SOURCE: long delay before can shoot another picture
This can happen when the card is nearly full or you've been deleting the pics but never formatting the card to give it a fresh start. Download any pics from the card and then format it in the camera.
t00nz
CameraR
  • 4738 Answers
  • Posted on Feb 09, 2010
SOURCE: Screen does not display images/camera will not take pictures
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
I have a moultrie A-5 gen 2 trail camera and the display screen keeps saying snap and won't take pics or video.???
Troubleshoot the issue and see if we can get it working properly:
Check the Camera Mode:
Make sure the camera is not in Handheld mode. If it is, switch it to Auto mode. The camera won't take pictures if the SD card is in Protect mode.
Review Settings:
Confirm that the camera is powered on.
Check if it's set to take photographs when it detects motion or if it's in time-lapse mode.
Perform an IR Filter Reset:
Take your camera into a completely dark room.
Walk or wave in front of the camera to trigger it to take a picture.
Turn on the lights and trigger the camera to take another picture.
Repeat this process 6 to 8 times. This will reset the IR filter, and better photos should be on the way.
Check the Viewing Screen:
Moultrie game cameras have a built-in viewing screen. Ensure that the screen is functioning properly.
If the display screen continues to show "snap" without capturing images or videos, consider contacting Moultrie customer support for further assistance.
Flash goes every time, even when there is no lightning bolt in the screen (for lack of better terms). Also a few photos turn out blue that were taken indoors.
210 wide camera is auto detect the environment. If you face it under bright light, the flash will auto off, if away from bright light, it will auto have flash. for photo have blue hue do show me the image, i take a look
1helpful
I want to scan a picture and make it A4 size
take a photograph of the spoons, depending on the camera quality, and the ability of the camera to take macro photographs, ( most of the modern cameras do have) Then take the photo into some sort of photo editing program, and enlarge the file/photo up to A4 at 300 dpi and print out
After Taking Photograph shows good in back screen but after transfering to Pc it shows very Dark why it so ?
use high quality speed card. secondly every camera company shows you bright picture because they want to cell their product with bright screen. so if you are a photographer then you ahve to use screen brightness and darkness in camera keep it on -2 setting
My fuji e900 digital camera keeps getting lines through the picture when I take a photograph . when you take the photo, its ok but when you you press the recall button to show the photo again, it has...
Does these pictures have the lines when you transfer them to a computer? If so,, than it is likely a capacitor needs to be changed out which is causing the interference. If it does not show up when you transfer them, than it may just be the review program on the camera.
2answers
Camera Screen does not show any picture
Are you sure that you have the EVF/LCD button is on LCD?
Camera not properly reading memory card
The problem stems from deleting some of the images from the PC. You need to copy all the files onto the PC, and delete all of them from the card on the camera. Then reformat the card on the camera. Then take 1 picture on the camera.
After you have just 1 new photo on the card, try copying the older files back onto the card in the same directory as the 1 new photo. This may work.
If it doesn't work, the problem may be with missing hidden thumbnail files. In that case you may not be able to get the photos to display on the camera again.
Direct image feed to digital Frame?
I just did a fast lookup and heres one frame
http://www.onecall.com/ProductDetails.aspx?id=89172
You can take the memory card with the pictures out from your camera and insert it into the picture frame and instantly view all the pictures from the card on the picture frame.
Nikon D40, how to display the date.
Select play back menu and select print time stamp.
For your Knowledge,do you like or not
All photographs taken with this camera having a data file with it, called meta data. All these file in formation can be viewed in clicking file info in photoshop.
The Metadata tags defined in the Exif standard cover a broad spectrum:
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
